A4 klimos ardymas |
magaizeris
Pranešimai: 1380
Įstojęs: 13.05.08 Miestas: Panevėžys
Parašyta 2009-10-28 09:58 |
sveiki,kaip a4 ardosi klimatronikas?taprasme kaip ja istraukti is savo vietos,kaip pritvirtinta
Redaguotas magaizeris 2009-10-28 10:19 |
RE: A4 klimos ardymas |
Dimkis
Pranešimai: 100
Įstojęs: 30.07.09 Šalis: Anglija
Parašyta 2009-10-28 11:53 |
ten kur isistato magnitofonas, atsuki du varztelius, nuemi plasmaske kuri eina aplinkui per vidurine panele, ir pamatisi klima irgri prisukta keleis varzteleis senokai ardziau, bet kazkaip taip buvo |
magaizeris
Pranešimai: 1380
Parašyta 2009-10-29 08:44 |
aciu,cia ta vis apdaila nuimt kur eina aplinkui visus priborus jo?nu kaip nors rasiu gal |
Parašyta 2009-10-29 08:48 |
zaibas parašė:
Does your climate control head unit not seem to be doing anything? If you push the buttons, nothing happens? Or, you can see the display, but the backlighting is not working? This how-to will help you get things working again.
The fix for the inactive display is pretty invasive, so be warned. If you are not reasonably good at soldering on circut boards, find a friend who is.
This will apply to 1996 and possibly 1997 Audi A4, possibly A6 models.
Bamperis prisegtas paveikslas:
Redaguotas Bamperis 2009-10-29 08:55 |
Parašyta 2009-10-29 08:49 |
Step one is to remove the radio. If you have an aftermarket radio, you should be able to just remove the trim plate, and unscrew the big wood trim plate. If you have the stock radio, you will NOT want to disconnect the harnesses unless you have the code handy. It is not really necessary to remove the harness anyway, as you should be able to slip the big trim over the radio and set it off to the side.
*NOTE* removing the stock radio requires special tools. You can get them at 'better' stereo shops, and at many VW/Audi Dealers. You insert them in the little slots in the radio, and pull the radio out using the tools as handles.
Once you get the trim off, you need to remove the CC head unit. There are 2 6mm Allens holding it in.
When you pull the CC head unit out, unclip the harness connectors (4 of them) from the back of the Head Unit. Keep in mind their order, though it would be pretty hard to get them back in the wrong order.
Redaguotas Bamperis 2009-10-29 09:00 |
magaizeris
Pranešimai: 1380
Parašyta 2009-10-29 09:24 |
oho paprasciau ir negali buti dabar aciu |
Parašyta 2009-10-29 09:31 |
zaibas parašė:
oho paprasciau ir negali buti dabar aciu Man tai būtų dar paprasčiau, jei rašytų lietuviškai ar rusiškai. Angliškai aš nė bum bum. Bet kompiuterinis vertimas leidžia pagaut mintį. |
magaizeris
Pranešimai: 1380
Parašyta 2009-10-29 09:42 |
nu tas tai jo,bet jau vaizdo uztenka pilnai |
magaizeris
Pranešimai: 1380
Parašyta 2009-10-30 10:51 |
beje gal kas ardet ir zinot klimos mygtuku apsvietima?ten lemputes keiciasi ar lituoti reikia |
Parašyta 2009-10-30 11:08 |
Keiciasi. Atskirai kiekvienam ekranui po lempute ir atskirai mygtukams.
www.saugosspektras.lt |
magaizeris
Pranešimai: 1380
Parašyta 2009-10-30 11:19 |
pfiuu tada puiku,dekuj,maniau mugtukams lituojasi |
liudzmaris
Pranešimai: 4409
Parašyta 2009-10-30 11:35 |
o mygtukam kokios lemputes dedasi? nes pas mane nei vienas nesviecia tik ekranai...
magaizeris
Pranešimai: 1380
Parašyta 2009-10-30 11:46 |
pz kas cia yra pas mane tas pats |
liudzmaris
Pranešimai: 4409
Parašyta 2009-10-30 11:48 |
ytariu jau kad ten tokios pat lemputes kaip b4 tu ratuku apsvietimo nes ten ir jas keist ir keist reikia
magaizeris
Pranešimai: 1380
Parašyta 2009-10-30 11:50 |
blemba atrodo nieko sunkaus iki jos daeit,bet kaip nesinori ardyt |
Parašyta 2009-10-30 11:57 |
Lemputes tokios, kaip i spidometro apsvietima. Su plastikiniu cokoliu, pasukamos.
magaizeris
Pranešimai: 1380
Parašyta 2009-10-30 12:16 |
aj tai labai viskas puiku tada |
liudzmaris
Pranešimai: 4409
Parašyta 2009-10-30 12:31 |
blin jei ten kiekvienam myktukui kita lempute tai jos 33lt kainuos pabusiu tamsoj iki vasaros bent
Parašyta 2009-10-30 12:33 |
Mygtukams 2 arba 4 lemputes. Nebeatamenu
Arte
Pranešimai: 200
Įstojęs: 30.07.07
Parašyta 2009-10-30 12:44 |
klimoj IS VISO 4ios lemputes eina kiek pamenu, po 2-3lt vnt. |
