Autorius ESP gedimas
only audi
Pranešimai: 405
Įstojęs: 11.01.10
Parašyta 2010-03-12 17:49
Gal kas patarsit kas per gedimas. Kompas raso , kad vairo posukio kampo (G85) mechaninis gedimas, ne elektrines grandines, o butent mechaninis. Pagal isore jokiu gedimu mechaniniu nesimato. Automobilis Audi A3 2001m, bet cia tur but visu modeliu vienodai, pas kuriuos yra ESP.
Autorius RE: ESP gedimas
Parašyta 2010-03-12 18:31
Pasidomejau biski, tai gali but,kad tiesiog apdulkejo tas jutiklis, tai reiktu isardyt, atsargiai isvalyt nieko nesugadinant ir surinkus sukalibruot. Sukalibruot galima su VAG COM.
only audi
Pranešimai: 405
Įstojęs: 11.01.10
Parašyta 2010-03-12 18:42
Jau buvau pilnai isardes, bet ten viskas svaru,del sukalibravimo tai nezinau kaip, dar tiek neismokau. Jeigu kas parasytumet proceduros eiliskuma buciau labai dekingas,bent jau kuriame kanale galima pamatyti pasukimo laipsnius.
Parašyta 2010-03-12 18:55
This procedure details how to perform the zero position calibration for the Steering Angle Sensor (G85) in many VW/Audi vehicles equipped with ESP (Electronic Stability Program). This procedure should be performed when vehicle alignment is performed or if any of the following components have been removed or replaced:
*ABS/EDL/ASR/ESP control unit (J104)
* Steering Angle Sensor (G85)
* Steering Column
There are certain test conditions that must be met before doing this procedure:
*Start the vehicle.
* Turn the steering wheel one turn to the right and one turn to the left.
* Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
*If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight
*Ensure that the steering wheel is not moved again.
* Keep the engine running and do not switch off the ignition.
Procedure for performing the zero position calibration for the Steering Angle Sensor (G85) on VW Golf, GTI, Jetta, and Audi TT:
[Select]
[03 - ABS Brakes]
[Login - 11]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 060
[Go!]
This will store the zero (centered) position of the steering wheel. There should be a displayed message that reads: "Steer. angle sender compens OK". If you get an error, it may mean the Login was not successfully performed.
Click the [Done, Go Back] button and you're all set.
Procedure for performing the zero position calibration for the Steering Angle Sensor (G85) on VW Passat and Audi A4/S4, A6/S6, and A8/S8:
[Select]
[03 - ABS Brakes]
[Login - 11]
Enter 40168
[Do It!]
Group 001
[Go!]
Redaguotas duba 2010-03-12 19:02
only audi
Pranešimai: 405
Įstojęs: 11.01.10
Parašyta 2010-03-12 19:25
Valio :o:o:o Gavosi ! O kokioj programoje tu radai visa sita aprasyma?
Parašyta 2010-03-12 19:45
Nu sutaupei kruvele pinigu :) Jei netingi padaryk lietuviska "pasidaryk pats" tema kaip sukalibruot :) Info is cia: http://www.ross-tech.com/vag-com/cars/steeringangle.html Jau kelinta kart sprendziant diagnostikos klausimus mane googlas cia atveda :)
Justassss
Pranešimai: 271
Įstojęs: 11.02.10
Parašyta 2014-07-16 19:22
o jum su kinišku vag comu leido logintis, ar normalius turit?
