Autorius a4 klaidu reiksmes patarkit
eley
Pranešimai: 113
Parašyta 2010-09-23 20:16
nuskanavau su vag-comu 409 klaidu sarasas patarkit kaip tvarkyti ka daryti.
Address 01: Engine
Controller: 028 906 021 CE
Component: 1.9l R4 EDC 00SG 0803
Coding: 00002
Shop #: WSC 06317
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 08: Auto HVAC
Controller: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D73
Coding: 04161
Shop #: WSC 06325
4 Faults Found:
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01297 - Sensor for Vent Temperature: Footwell (G192)
30-00 - Open or Short to B+
01296 - Sensor for Vent Temperature: Center (G191)
01206 - Signal for Duration of Ignition: OFF
27-10 - Implausible Signal - Intermittent
Address 15: Airbags
Controller: 8A0 959 655 C
Component: Airbag V AUDI D00
Coding: 01022
Shop #: WSC 06315
1 Fault Found:
01025 - Trigger for On Board Diagnostic Lamp: Malfunction
Address 17: Instruments
Controller: 8D0 919 035 Q
Component: B5_KOMBIINSTRUMENT D09
Coding: 00142
Shop #: WSC 06035
Address 25: Immobilizer
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0T3756281 D77
Coding: 00000
Shop #: WSC 00064
1 Fault Found:
01176 - Key
07-10 - Signal too Low - Intermittent
End --------------------------------------------------------------------------------------------------
Autorius RE: a4 klaidu reiksmes patarkit
eley
Pranešimai: 113
Parašyta 2010-09-23 20:18
25 - tai imobilaizeris kaip ji tvarkyti ? gal kokia fiske reik ziureti ar kas ten?
17 tai airbagu lempute dega man, kaip ja uzgesinti? uzsidegoe kai keiciau spidometra.
bet kas tas 08 ? cia klima? kokios cia klaidu reiksmes?
only audi
Pranešimai: 405
Įstojęs: 11.01.10
Parašyta 2010-09-23 22:37
Jeigu imobilaizerio lempute uzgesta, tai nekreipk demesio i ta klaida, air bag tai tik istrink klaida ir uzges, kondiskes pirma klaida, kad nera freono spaudimo, antra trecia tai nemato temperaturiniu davikliu po vairuotojo kojom ir centrinej konsolej, bet gali buti ir sklendes pristrigusios, o ketvirta tai nelabai zinau kas cia, gal kas protingesnis patars. Del klimos tai paieskok forume kaip su pacia klima paziureti per kanalus gedimu kodus.
eley
Pranešimai: 113
Parašyta 2010-09-24 08:26
aciu.
dar klausymas kai baigiasi freonas kompas atjungia pati siurbli kad bereikalo nedirbtu? su imobilaizeriu tai turesiu bedu nes istisai neina uzvesti masinos, bandysiu sian prie fiskiu kisti nagus sako a4 liga kazkokios fiskes dantukai iskleba... del sklendiu tai jo matyt bus jos uzpuvusios nes ir likusias su garsais darineja :D
only audi
Pranešimai: 405
Įstojęs: 11.01.10
Parašyta 2010-09-24 15:38
eley parašė:
aciu.
Palauk, o ko tu lindai prie skydelio, gal kartais pakeitei, nes ten stovi imoilaizeris.
Parašyta 2010-09-24 16:20
imobilaizerio blokas atskiras sitoje audi.
eley
Pranešimai: 113
Parašyta 2010-09-24 18:18
keiciau nes spidometras nebeveike nei apsuku rodykle nei greicio, tik angliska isidejau pasikeiciau ciferblatus ir viskas ok tik po kiek laiko zusidege airbag lempute..... Su imobilaizeriu dabar jau viskas ok isardes ta fiske maza 2 kontaktu ,kuri ieina i spineles prieki pastebejau kad dantukai kazaip sleivai kreivai stowi patiesinau suspaudziau ir dabar viskas OK :) kuriasi be proplemu nebegesina. liko tik kazkaip air bag lempute uzgesinti nes istrynus klaida ji vel iskarto atsiranda. gal del to kad pakaitinimo lempute atjungta??? :| bet ji ateina is kazkur kitur ne is spidometro...... ir niekaip neiseina pakeisti is myliu i km spidometra keiciu skaiciu reiksme bet kaip mylios taip mylios tauksi ciaksi tas spidometras keitinejant bet niekaip km nepasidaro :(
Redaguotas eley 2010-09-24 18:20
Parašyta 2010-09-24 18:27
eley parašė:
Tai ziurek, kodel klaida atsiranda. Raso gi.
eley
Pranešimai: 113
Parašyta 2010-09-24 18:57
Gaidukas Dėl diagnostikos Lempos: Sutrikimas :D va kaip google vercia :D
eley
Pranešimai: 113
Parašyta 2010-09-25 09:36
na va liko tik viena problema kaip is myliu perversti i km "00140" nei "00040" nekeicia i km nors pagal aprasyma turetu
00 - klaidu ispejimai
1 - salis / h
4 - cilindrai
0 - TDI variklatis
ptik pastebejau kad ant seno skidelio buwo uzrasas VDO o ant dabartinio UK-NSI . gal skiriasi koduote? ar kito laido reikia? ar kitam kokiam kanale keisti nustatymus?
p.s pastebejau kad ant spidometro raso kad auto prabegus 230000 o per kompa rodo 390000 tai kurie parodymai cia teisingi? :)
Redaguotas eley 2010-09-25 09:37
eley
Pranešimai: 113
Parašyta 2010-09-25 09:38
vnz kuo giliau i miska tuo daugiau medziu......:(
only audi
Pranešimai: 405
Įstojęs: 11.01.10
Parašyta 2010-09-25 15:24
p.s pastebejau kad ant spidometro raso kad auto prabegus 230000 o per kompa rodo 390000 tai kurie parodymai cia teisingi? :)[/quote]
Teisingas kur kompas rodo, o ne skydelis. Vienam vw skydelis rode 168000, o kai pajungiau kompa vos nenukritau 648000. Yra dalis kompu kurie issaugo tikra rida, kiek nori gali atsukti, bet tikru parodymu neistrinsi.
eley
Pranešimai: 113
Parašyta 2010-09-26 09:25
mhmh tai taip ir maniau kad bus daugiau prabegus nei 180000 kai pirkau :) reiks i man parduodant atsukti :)
only audi
Pranešimai: 405
Įstojęs: 11.01.10
Parašyta 2010-09-26 10:30
eley parašė:
Jeigu protingas pirkejas, nieko neiseis, paims tech. apziuros lapa ,o ten yra rasoma rida.
aauudriukas
Pranešimai: 151
Įstojęs: 12.10.11
Parašyta 2013-09-18 14:00
sveiki klubieciai gal kas zino kas per klaida? 00626 Plug indicator light (K29) aciu is anksto
foryoumarius
Pranešimai: 487
Įstojęs: 10.09.09
Miestas: Marijampolė
Parašyta 2013-09-18 15:34
mano manymu pas tave skydelyje nedega pakaitinimo žvakių lemputė.
