Autorius b7 multitronic klaidos
PHObas55
Pranešimai: 30
Įstojęs: 27.12.09
Parašyta 2013-02-05 10:55
sveiki, turiu tokia beda, pas mane kartais PRNDS dega raudonai arba mirkcioja, tada taip atroda kad paveluotai isijunga pabvaros kai jungi P ar R, su kompu parode tokias klaidas :
Address 02: Auto Trans Labels: User\01J-927-156.lbl
Control Module Part Number: 8E1 910 155 HW: 01J 927 156 HT
Component and/or Version: V30 01J 2.0TFSI RdW 0030
Software Coding: 0000001
Work Shop Code: WSC 00415 210 57172
VCID: E3CE2DD21D0F2E04
3 Faults Found
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 000 - - - Intermittent
Freeze Frame
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 148
Time Indication: 0
Freeze Frame
RPM: 928 /min
RPM: 0 /min
(no units): 13.0
Torque: -10.0 Nm
Temperature: 39.0°C
T.B. Angle: 0.0°
Bin. Bits: 0001 0 0
18201 - Transmission Output Speed Sensor 2 (G196): No Signal
P1793 - 000 - -
Freeze Frame
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 254
Time Indication: 0
Freeze Frame
RPM: 1312 /min
RPM: 90 /min
(no units): 3.0
Torque: 98.0 Nm
Temperature: 50.0°C
T.B. Angle: 17.2°
Bin. Bits: 1010 0 0
17106 - Transmission Output Speed Sensor (G195): No Signal
P0722 - 000 - -
Freeze Frame
Fault Priority: 0
Time Indication: 0
Freeze Frame
RPM: 1344 /min
RPM: 0 /min
(no units): 16.0
Torque: 6.0 Nm
Temperature: 54.0°C
T.B. Angle: 0.0°
Bin. Bits: 1010 0 0
gal kas esat susidure? ka reiketu daryt, ar sunku sutvarkyt?
