klimos ekranas |
marius0722
Pranešimai: 117
Įstojęs: 16.06.09 Vairuoja: Audi A6
Parašyta 2010-11-27 09:41 |
SVEIKI, SIANDIEN SAPNAVAU ARBA KAZKADA KAI DAR NETUREJAU AUDI, MACIAU TOKI BAJERI KAD KLIMOS EKRANAS RODE KAZKA KITO, NE TIK TEMPERATURA BET GREITI KURO SANAUDAS IR PAN, CIA LIECIA SENESNIO GYMIO AUDI KAIP A6 C4, IR PAN, ZODZIU TEST NESKUBEKIT BET TOKI BAJERI KAZKUR MACIAU, AKTUALU BUTU TIEK PAS KA NERA KOMPO. TAI VA |
RE: klimos ekranas |
kodis
Pranešimai: 161
Įstojęs: 22.01.10 Vairuoja: Audi A4
Parašyta 2010-11-27 09:59 |
"Klimos nustatymai"
1. Press Fan Down, Temperature Colder, ECON at the same time.
2. Use the temperature control buttons to cycle through the various channels to Channel 16.
3. Press ECON to go back to normal. (It goes back automatically when you restart the car.)
Taip, dvieju ekranu klimato valdymas:
-paspausti ir laikyti recirkuliacijos mygtuka (deshini apatini, su nupieshta mashina)
-tuo pat metu paspausti deshini virshutini mygtuka (rodykle i virshu),
-abu mygtukus atleisti.
kairiajame ekrane pasirodys kanalu numeriai
-vaikscioti per kanalus su + ir - mygtukais po kairiuoju ekranu
- ieinama i kanala paspaudus recirkuliacijos mygtuka
The channels that I know the meaning of are:
1 Interior temperature (sensor)
3 Sunlight sensor
7 Coolant temperature sensor
9 Blower speed (adjustable)
10 Measured blower speed (sensor)
11 Defog valve (adj. 0-255)
12 Dashboard ventilation valve (adj. 0-255)
13 Recirculation valve (adj. 0-255)
14 Lower ventilation valve (adj. 0-255)
16 Speed (sensor)
OR
Contents of 1 system error # system error
2 actual value feeler virtually # actual VALUE sensor virtual
3 actual value of interior feelers console # actual VALUE internal sensor CONSOLE
4 actual value outside temperature feeler wasserkasten # actual VALUE outside temp sensor water reservoir
5 actual value outside temperature feeler bumper # actual VALUE outside temp sensor more bumper
6 actual value blowing out feeler floor space # actual VALUE bloweroutlet sensor footspace
7 actual value blowing out feeler Mannanstroemer # actual VALUE bloweroutlet sensor dashboard
8 display CHECKS #
9 actual digital value answering potentiometer temperature flap # actual digitally VALUE feedback potentiometer temp valve
10 debit digital value temperature flap # set digitally VALUE temp valve
11 actual digital value answering potentiometer A/C flap
12 debit digital value A/C flap
13 actual digital value answering potentiometer Fuss/Def. Flap
14 debit digital value Fuss/Def. Flap
15 actual digital value answering potentiometer ram air flap
16 debit digital value ram air flap
17 driving speed (km/h) 16
18 actual value of the blower voltage (volt) 19 desired value of the blower voltage (volt)
20 actual value of the compressor/on-board voltage (volt)
21 amount of of low-voltage events (not volatile)
22 switching status of the high pressure feeler
23 number of high pressure events (volatile)
24 number of high pressure events (not volatile)
25 A/D value kickdown switch
26 A/D value hot light
27 engine speed
28 compressor number of revolutions
29 coding
30 software-Version
31 software index of
32 potentiometer error counters temperature flap of
33 potentiometer error counters A/C flap of
34 potentiometer error counters Fuss/def. Flap of
35 potentiometer error counters ram air flap
36 temperature flap impact coldly
37 temperature flap impact warmly
38 A/C flap impact closed
39 A/C flap impact openly
40 Fuss/Def. Impact Def folds.
41 Fuss/Def. Impact foot
42 ram air flap impact on
43 ram air flap impact folds to
44 operating cycle counters
45 interior temperature counted (Nine) dig
46 outside temperature filtered °C
47 outside temperature not filtered °C
48 ECOR of
49 error counters Tachosignal
50 service life in min
51 engine temperature °C
52 compressor power-off conditions (appendix)
53 display more actively el. Outputs x x compressor circulating air valve x water valve
54 rule code digit
55 outside temperature °C of
56 interior feelers virtually °C of
57 interior feelers console °C
58 temperature wasserkasten °C
59 temperature bumper °C of
60 blowing out feelers floor space °C of
61 blowing out feelers Mannanstroemer °C
62 sun intensity W/m² 3
63 sun intensity filtered W/m²
64 delta exhaust rise
65 delta A/C flap shift
66 time constant 1.8 seconds of
67 cold weather starting correction
68 max. correcting variable for i or sectionsection section of
69 actual value blowing out feeler foot (cnts)
70 desired value blowing out feeler foot (cnts)
71 deviation (Epsilon)
72 proportion (+heizen - cool)
www.TopSex.lt
www.autofanai.lt
www.travel-info.lt
www.lenta24.lt
www.topcar.lt
www.pump.lt |
marius0722
Pranešimai: 117
Parašyta 2010-11-27 18:50 |
siaubingai dekoju |
Laurynas
Pranešimai: 168
Įstojęs: 08.08.10 Miestas: Vilnius
Parašyta 2010-12-03 14:30 |
o as dundukas nelabai suprantu angliskai
gal galit kas isversti tiksliai? nes per google isvercia su netikslumais
Redaguotas Laurynas 2010-12-03 14:47 |
Laurynas
Pranešimai: 168
Parašyta 2010-12-08 14:02 |
turiu visas komandas (61) rusu ir lietuviu kalba, aciu, kad vel nepadejot
bei kalaidu paaiskinimus
Redaguotas Laurynas 2010-12-08 14:04 |
Parašyta 2010-12-11 18:50 |
Laurynas parašė: turiu visas komandas (61) rusu ir lietuviu kalba, aciu, kad vel nepadejot bei kalaidu paaiskinimus
Laurynai, įdėk lietuviškai, ką?
Gugis
Pranešimai: 69
Įstojęs: 31.03.10 Vairuoja: Audi 100
Parašyta 2011-01-08 13:09 |
sveiki, norejau paklaust kaip isjungti farengeitus? |
Parašyta 2011-01-08 13:58 |
Gugis parašė:
sveiki, norejau paklaust kaip isjungti farengeitus? pamyk masinytes simboli ir tada pliusa kur siluma reguliuoji ir pasidaris celsijus |
raiminukas
Pranešimai: 362
Įstojęs: 02.08.08 Miestas: Utena
Parašyta 2011-01-08 19:32 |
o gal kas pamena kaip padaryt taip, kad temperatura nusistatynetu per abu ekranus maigant tik vairuotojo pusej (tuo paciu keistus ir keleivio pusej temp.)
hi-end fanas! the best of the best, of the best (pakeliui i tai...) |
Parašyta 2011-01-08 19:43 |
as zinau kaip padaryt kad greiti rodytu klimoj
QUATTRO TDI POWER #145 |
Parašyta 2011-01-16 22:08 |
Juk parasiau i PM
Laurynas
Pranešimai: 168
Parašyta 2011-01-16 22:10 |
ko cia giriates del to, kad greiti rodo? Juk viskas surasyta pirmame poste, kas ka reiskia galima gi ir apsukas ir greiti, ir salono bei lauko temperatura, antifrizo temperatura, ir daugelis kitu
Parašyta 2011-01-16 22:44 |
markotdi parašė:
as zinau kaip padaryt kad greiti rodytu klimoj man rodos greiti patogiau spidometre ziureti. |
Parašyta 2011-01-16 22:54 |
toto parašė:
markotdi parašė:
as zinau kaip padaryt kad greiti rodytu klimoj man rodos greiti patogiau spidometre ziureti. Bet spidometras meluoti linkes,o klima arciau teisybes rodo.
Parašyta 2011-01-16 22:57 |
Dubinskas parašė:
toto parašė:
markotdi parašė:
as zinau kaip padaryt kad greiti rodytu klimoj man rodos greiti patogiau spidometre ziureti. Bet spidometras meluoti linkes,o klima arciau teisybes rodo. o kaip i kelia ziureti?o meluoja moterys geriau.. |
Parašyta 2011-01-16 23:00 |
toto parašė:
Dubinskas parašė:
toto parašė:
markotdi parašė:
as zinau kaip padaryt kad greiti rodytu klimoj man rodos greiti patogiau spidometre ziureti. Bet spidometras meluoti linkes,o klima arciau teisybes rodo. o kaip i kelia ziureti?o meluoja moterys geriau.. Rasyk skunda vokieciams,kad taip durnai sugalvojo O kam tada klima temperatura rodo? turetu issijungti ekranelis, kai tik masina pajuda,kad neblaskytu vairuotojo demesio. Sita irgi gali pamineti
Parašyta 2011-01-16 23:15 |
Dubinskas parašė:
toto parašė:
Dubinskas parašė:
toto parašė:
markotdi parašė:
as zinau kaip padaryt kad greiti rodytu klimoj man rodos greiti patogiau spidometre ziureti. Bet spidometras meluoti linkes,o klima arciau teisybes rodo. o kaip i kelia ziureti?o meluoja moterys geriau.. Rasyk skunda vokieciams,kad taip durnai sugalvojo O kam tada klima temperatura rodo? turetu issijungti ekranelis, kai tik masina pajuda,kad neblaskytu vairuotojo demesio. Sita irgi gali pamineti diskusija be ateities.Yra spydasir jame rodo visa info vairuotojui,o klimos maigymas yra vaiku zaidimas. |
von
Pranešimai: 715
Įstojęs: 27.03.09 Miestas: Kaunas
Parašyta 2011-01-16 23:16 |
Gal kas galetu imesti LIETUVIU kalba sios klimos vertima??? Nes google translate daugiau nei puse isvercia kazkokia ciukciam suprantama kalba
Audi A3 (8L) 1.9TDI
Audi A4 (B6) 1.9TDI |
Direktorius
Pranešimai: 1044
Vairuoja: Audi RS6
Parašyta 2011-02-04 23:05 |
Ka reiskai snaige kur rodo lauko temperatura skydelije (kur greitis ,apsukos ir t.t.) ? siandien buvo +2.5 ir salia snaige .. Cia gal kad negalima jung kondicionieriaus ? Nes kazkaip jsi berods veikia tik nuo +5 ? Ar ta snaige visada buna ? Siandien teatkreipiau demesi ... Bei dar klausimas, kas buna jei klimoj ijungi ta snaige, bet uzstatytas temperatura pati auksciausia karstam orui ? Kazko klima susipjauna kartais ir ta snaige pati isijungia, o vaziuoju tai su siluma ir nebeina atjungt, pabuna tada vel sureguoja, na reikes ardyt kazkada tuos mygtukus tvarkyt, bet nieko logo kad ji isijungia ir kazkiek pabuna ~ 5-10 min, nes po tiek laiko sureaguoja kad eitu isjungt ;/
Redaguotas Direktorius 2011-02-04 23:07 |
q u a t t r o
Pranešimai: 1816
Įstojęs: 19.06.10 Šalis: Rusija
Parašyta 2011-02-05 09:53 |
snaige perspeja kad gali buti slidu, slapia ir t.t. ten jos dvi yra, viena kairej pusej temperaturos uzsidega, kita kitoj puse. nesigilink ten geriau... neisgeres nesuprasi. paspaudus ta snaige isijungia kondicionierius, buna ir pas mane kad ji pati isijungia, bet retai, paprasciausiai isjungiu ir viskas. o kodel ji pas tave bliudija nezinau. |
