Autorius AUDI a6 c6 nesikuria
go0dby3
Pranešimai: 6
Įstojęs: 20.09.14
Parašyta 2014-10-17 17:02
Šaltas variklis sunkiai kuriasi gana ilgai suka starteris, bet pasiles antra karta jau lengviau, kartais neuzsikuria kelis kartus bet poto uzsikuria. O dabar nebesikuria isvis, akumas geras, kuriant kai paleidi rakta pasuka ir pati nustoja, o kai laikai pasukes rakta suka ir mirksi pakaitinimo zvakes lempute. Viena sklende nedirba bet jau seniai manau nesusije neturejau laiko dar pasitvarkyt. VCDS meta va ka:
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 J HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 01941 264 93731
VCID: 234FF7CCE22B3906A91-8076
8 Faults Found:
000802 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 220714 km
Time Indication: 0
Date: 2005.10.13
Time: 08:37:28
Freeze Frame:
RPM: 0 /min
Torque: 226.2 Nm
Speed: 0.0 km/h
(no units): 128.0
Voltage: 11.25 V
(no units): 134.4
(no units): 151.2
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 220714 km
Time Indication: 0
Date: 2005.10.13
Time: 08:37:30
Freeze Frame:
RPM: 147 /min
Torque: 226.2 Nm
Speed: 0.0 km/h
Voltage: 11.70 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 20.5 %
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 33
Reset counter: 255
Mileage: 220713 km
Time Indication: 0
Date: 2005.09.20
Time: 12:00:37
Freeze Frame:
RPM: 0 /min
Torque: 218.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Torque: 93.6 Nm
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached
Freeze Frame:
Fault Priority: 0
Fault Frequency: 14
Reset counter: 255
Mileage: 220713 km
Time Indication: 0
Date: 2005.09.20
Time: 12:02:49
Freeze Frame:
RPM: 0 /min
Torque: 195.0 Nm
Speed: 0.0 km/h
Voltage: 12.01 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
012696 - Control Circuit for Intake Manifold Runner (Bank1)
P3198 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 220713 km
Time Indication: 0
Date: 2005.09.20
Time: 12:07:51
Freeze Frame:
RPM: 777 /min
Torque: 78.0 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Duty Cycle: 0.4 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
008200 - Intake Manifold Flap; Bank 1
P2008 - 001 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 220713 km
Time Indication: 0
Date: 2005.09.20
Time: 12:07:51
Freeze Frame:
RPM: 777 /min
Torque: 78.0 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Duty Cycle: 0.4 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
008201 - Intake Manifold Flap; Bank 1
P2009 - 001 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 220713 km
Time Indication: 0
Date: 2005.09.20
Time: 12:08:36
Freeze Frame:
RPM: 777 /min
Torque: 78.0 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 0.4 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
005481 - Cruise Control Switch (E45)
P1569 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 6.08 V
Bin. Bits: 00001100
Torque: 93.6 Nm
Readiness: 0 1 0 X 0
Gal kas turi kokiu minciu buciau labai dekingas :)
Autorius RE: AUDI a6 c6 nesikuria
Pranešimai: 1663
Įstojęs: 24.10.11
Parašyta 2014-10-17 19:36
rodo, kad tavo holo daviklis gatavas. is jo negauna signalo. pabandyk kontaktus patikrint, o gal ir keist reiktu
go0dby3
Pranešimai: 6
Įstojęs: 20.09.14
Parašyta 2014-10-21 10:57
O del ko parejo tas holo daviklis cia man negali pasakyt? Kazka skaiciau kad varikliui gali amen but
Pranešimai: 1663
Įstojęs: 24.10.11
Parašyta 2014-10-21 12:00
Nuo senumo sugenda jie... nieko cia baisaus. Tik pirmiau laidus pasitikrink ir fyske, gal ten beda bus :) o del motor kaput, tai net nzn. Susitvarkyk pirmiau tokius reikalus ir tada matysi. nes jei holas lievas, net nesitikek, kad motoras normlaiai dirbs
