Autorius
Audi A6 C6 3,0TDI 171kw nesikuria po purkštukų keitimo
Dmitrij
Pranešimai: 20
Įstojęs: 01.01.15Miestas: Vilnius
Vairuoja: Audi A6 Allroad
Parašyta 2016-09-15 23:25
Sveiki. Po purkštukų keitimo nebeužsiveda. Toks jausmas, jog kurą nepaduoda. Gal galit patarti nuo ko pradėti tikrinti?
Štai ka rodo diagnostika
Thursday,15,September,2016,20:11:01:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ4F07N075436 License Plate: NAUJAS
Mileage: 289290km-179756mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 42 46 47 4F 52 53
55 56 61 62 6C 72 76 77
VIN: WAUZZZ4F07N075436 Mileage: 289290km/179756miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 S HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H03--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 2D5B11F4B4EFFF760F5-8078
2 Faults Found:
001653 - Cylinder 5 Glow Plug Circuit (Q14)
P0675 - 000 - Electrical Fault
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:01:17
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.25 V
Duty Cycle: 11.0 %
Temperature: 15.3°C
001654 - Cylinder 6 Glow Plug Circuit (Q15)
P0676 - 000 - Electrical Fault
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:01:17
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.25 V
Duty Cycle: 11.0 %
Temperature: 15.3°C
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0040
Revision: --H01--- Serial number: 4249036
Coding: 0000001
Shop #: WSC 02331 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
Component: ESP 8.0 quattro H05 0040
Revision: 00000000 Serial number: 00000000000000
Coding: 0016776
VCID: 64CDB4D0A7A57E3E10B-8031
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100574273
Coding: 0000131
Shop #: WSC 53522 000 1048576
VCID: E3CF37CC22ABF906691-80B6
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 S HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 351JK067530071
Coding: 0003006
Shop #: WSC 00000 000 08192
VCID: 32610288ADD1A08E527-8067
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000568383
Subsystem 3 - Serial number: 0130.10.060000000100011149˙
Subsystem 4 - Serial number: 011149˙
1 Fault Found:
00658 - Control Head
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 289219 km
Time Indication: 0
Date: 2016.09.03
Time: 16:02:09
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000000318608
Coding: 0004374
VCID: 1C3DCC30DF5506FE68B-8049
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H15 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0013122
Shop #: WSC 02335 785 00200
VCID: 31630D84A8D79B962BD-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 A HW: 4E0 035 110 A
Component: MP3-Changer H44 0270
Revision: 00044000 Serial number: AUZ5ZBF3101737
Shop #: WSC 00000 000 00000
VCID: 1629DE1821795CAE5EF-8043
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 226
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:55:28
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 178
Mileage: 253251 km
Time Indication: 0
Date: 2006.05.10
Time: 12:02:25
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0HCMS.
Coding: 0013362
Shop #: WSC 02325 785 00200
VCID: 2953E5E48007E356E3D-807C
Subsystem 1 - Serial number: 6332CSME146A496DE
Subsystem 2 - Serial number: 6342CSME13261901S
Subsystem 3 - Serial number: 6352QSME17760F4BS
Subsystem 4 - Serial number: 6362QSME180344378
Subsystem 5 - Serial number: 63734SME151B1B27/
Subsystem 6 - Serial number: 63834SME152B3435-
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054063010038
Coding: 0002042
VCID: E6C92ED8D1998C2E8EF-80B3
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 932
Component: KOMBIINSTR. M73 H18 0120
Revision: 00600000 Serial number: 5HP74FJA6
Coding: 6249148
Shop #: WSC 00999 444 64523
VCID: 234FF7CCE22B3906A91-8076
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 10
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:56:49
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A158130
Coding: F551DE7F303206
VCID: ECDD5CF0CF75B67ED8B-80B9
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0060
Serial number: 00619002322600
Coding: 0000210
VCID: 2241F2C8FD31300EA27-8077
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 L
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364JV067606407
Shop #: WSC 00859 400 87080
VCID: 3B7F2FAC7A9B61C6811-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0170
Revision: 00-00000
Coding: 0001578
Shop #: WSC 02327 785 00200
VCID: 2C5D1CF08FF5F67E18B-8079
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01022783970000
Coding: 0402161
VCID: 2E5916F8B9E9846E36F-807B
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
2 Faults Found:
01519 - Bulb for Back-Up Lights; Right (M17)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 226
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:50:09
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 226
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:50:12
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000000919
Coding: 0000112
VCID: 254BE9D4EC1FC736C75-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000291528
Coding: 0001113
VCID: DEB9063809C9D4EE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0170
Revision: 00-00000
Coding: 0001578
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0000321
Shop #: WSC 02324 785 00200
VCID: 1F47FB3CCE431DE68D9-804A
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000017
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 394J4067696771
Coding: 0000001
VCID: 2A511AE88501E84EEA7-807F
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000119467
Shop #: WSC 03214 995 56900
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2610204262
Coding: 344630393135313035442056413032363130323034323632
Shop #: WSC 00000 512 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:58:36
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:04:46
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:04:56
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:05:22
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:05:32
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0001066
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J69306E
Coding: 1020205
VCID: 1E39C638C94914EE86F-804B
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0001066
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330629602318
Coding: 0221416
VCID: 2855E0E09B0DDA5EFC3-807D
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007594093
Coding: 0010930
End
Autorius
RE: Audi A6 C6 3,0TDI 171kw nesikuria po purkštukų keitimo
A90A
Pranešimai: 1197
Įstojęs: 31.12.13Miestas: Prienai
Parašyta 2016-09-15 23:30
Purkstukus tikrino ar tik gerus dejai ?
Autorius
Dmitrij
Pranešimai: 20
Parašyta 2016-09-15 23:32
Purkštukai nauji. Tai netikrinau.
Autorius
Įstojęs: 04.08.09Miestas: Vilnius
Parašyta 2016-09-15 23:36
itariu, kad uzsiorino ;] ziurek koks reilo slegis ir bus aisku ar ateina kuras
Autorius
Dmitrij
Pranešimai: 20
Parašyta 2016-09-15 23:41
Kai su VCDS tikrinau (out put test) tai kuro siurblys slėgio išvis nerodė.
Autorius
Įstojęs: 28.12.07Miestas: Vilnius
Parašyta 2016-09-16 08:34
Pūstelk eterio, pažiūrėk ar griebia .
Autorius
Parašyta 2016-09-16 18:51
Ne output test reik, o tiesiog ziureti rail pressure. Jei manualas, bandyk buksiruot. Jei automatas, tai arba pripompuok kuro, arba kaip sako su eteriu varyk.
Autorius
Dmitrij
Pranešimai: 20
Parašyta 2016-09-21 21:09
Ačiu eteris padejo
Autorius
streetaz23
Pranešimai: 36
Įstojęs: 24.04.15Vairuoja: Audi A6
Parašyta 2016-09-26 21:02
Ir kiek suklojai uz purkstukus?
Taisyklės
Teisininko konsultacijos
Prevencinės akcijos!!! Svarbu...
Klausimai - atsakymai
ĮVAIRIOS AUDIFANŲ DISKUSIJOS
VAG IR KT. GIMININGŲ AUDI MARKEI AUTOMOBILIŲ FORUMAS
MEETAI
Auto sportas, renginiai
Fotografijos, Video
Žaidimai
Pasidaryk pats
Atributika
ŠIUKŠLIADĖŽĖ
AUDI - Coupe, Cabrio, TT
AUDI - 80, 90, Avant. [B3, B4]
AUDI - 80, 90, COUPE [B2]
Audi - 100, 200, 5000 ir kt.
AUDI - A3, S3
AUDI - A4, S4, RS4
AUDI - A5, S5
AUDI - A6, S6, RS6
AUDI - A7, S7, RS7
AUDI - A8, S8, V8
AUDI - Apie ja ir dėl jos
Mano AUDI
Bendros diskusijos apie dyzelius
Remontas
Priežiūra ir modifikacijos
APSAUGOS SISTEMOS
VARIKLIAI
REMONTAS
KITOS BĖDOS
Auto sporto renginiai
Variklio ir transmisijos modifikacijos
Kėbulo modifikacijos
Pakabos modifikacijos
Elektronika ir salonas
Saugumas ir vairavimo technika
AKUSTIKA
GROTUVAI
STIPRINTUVAI
ŽEMADAŽNIAI GARSIAKALBIAI
Pamokėlės tvarkant forumą
Svetainės redakcija
Nauja
