b7 2.0tfsi 147kw diagnostikos klaidos |
PHObas55
Pranešimai: 30
Įstojęs: 27.12.09 Miestas: Vilnius
Parašyta 2014-07-08 14:59 |
sveiki, nuvariau sian masiniuka i diagnostika, dege chekas ir purtesi ant laisvu, tai pradziai nuskaite klaidas jos buvo tokios:
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8E0 910 115 J HW: 8E0 907 115 C
Component and/or Version: 2.0l R4/4V TFSI 0080
Software Coding: 010C000302070120
Work Shop Code: WSC 00415 210 81338
VCID: 285F13B89BE10C7A07-807D
13 Faults Found:
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 188
Reset counter: 255
Mileage: 125876 km
Time Indication: 0
Freeze Frame:
RPM: 1282 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 40.0?C
Temperature: 27.0?C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
009537 - Low Pressure Fuel Sensor (G410)
P2541 - 002 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 125877 km
Time Indication: 0
Freeze Frame:
RPM: 1358 /min
Load: 71.0 %
Speed: 9.0 km/h
Temperature: 87.0?C
Temperature: 36.0?C
Voltage: 14.097 V
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 125876 km
Time Indication: 0
Freeze Frame:
RPM: 745 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 92.0?C
Temperature: 54.0?C
Voltage: 13.716 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Reset counter: 255
Mileage: 126168 km
Time Indication: 0
Freeze Frame:
RPM: 1532 /min
Load: 49.8 %
Speed: 45.0 km/h
Temperature: 84.0?C
Temperature: 37.0?C
Voltage: 13.843 V
001089 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 126192 km
Time Indication: 0
Freeze Frame:
RPM: 748 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 84.0?C
Temperature: 31.0?C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 127447 km
Time Indication: 0
Freeze Frame:
RPM: 748 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 105.0?C
Temperature: 52.0?C
Voltage: 13.843 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 127447 km
Time Indication: 0
Freeze Frame:
RPM: 1467 /min
Load: 11.4 %
Speed: 0.0 km/h
Temperature: 52.0?C
Voltage: 13.970 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 127447 km
Time Indication: 0
Freeze Frame:
RPM: 1467 /min
Load: 11.4 %
Speed: 0.0 km/h
Temperature: 52.0?C
Voltage: 13.970 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 127447 km
Time Indication: 0
Freeze Frame:
RPM: 1467 /min
Load: 11.4 %
Speed: 0.0 km/h
Temperature: 52.0?C
Voltage: 13.970 V
008825 - Leak in Air Intake System
P2279 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 129649 km
Time Indication: 0
Freeze Frame:
RPM: 850 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 84.0?C
Temperature: 38.0?C
Voltage: 13.970 V
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 129665 km
Time Indication: 0
Freeze Frame:
RPM: 3434 /min
Load: 87.8 %
Speed: 76.0 km/h
Temperature: 86.0?C
Temperature: 21.0?C
Voltage: 13.716 V
008200 - Intake Manifold Flap; Bank 1
P2008 - 001 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 130329 km
Time Indication: 0
Freeze Frame:
RPM: 2574 /min
Load: 10.2 %
Speed: 102.0 km/h
Temperature: 85.0?C
Temperature: 25.0?C
Voltage: 13.970 V
012600 - Intake Manifold Runner Control
P3138 - 008 - Regulation Deviation
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 130329 km
Time Indication: 0
Freeze Frame:
RPM: 2574 /min
Load: 9.8 %
Speed: 102.0 km/h
Temperature: 85.0?C
Temperature: 25.0?C
Voltage: 13.970 V
Readiness: 0000 0001
istrine ir per naujo paziurejo kokias ismeta, o ismete tokias:
Software Coding:
Work Shop Code:
VCID: 55A16A4CAC1341926C-FFFF
6 Faults Found:
P2279 - 002 -
P0300 - 008 -
000769 - Cylinder 1
P0301 - 008 - Misfire Detected
000771 - Cylinder 3
000772 - Cylinder 4
000770 - Cylinder 2
del ko gali but tie misfire, pamatavom komporesija visur po 13, pakeitem zvakes, bet tas pats nenoretusi tiket kad ir babinos bus, nes kaip ir vienu metu visos sugesti negalejo, galvota buvo apie N80, bet turi ji ismest per atra kliadu skaityma,, (bent jau taip galvoju) kas turi kkokiu minciu, gal kokios klaidos susijusios is pirmo skaitymo |
RE: b7 2.0tfsi 147kw diagnostikos klaidos |
Elektrik
Pranešimai: 1334
Parašyta 2014-07-08 17:09 |
Sveikas,
na babinas galiu duoti patikrinti ketvirtadienį per meetą jeigu važiuoja mašina (turiu pas save pasistatęs FSI/TFSI babinas) o šeip leak testą reiktų dar padaryti ir pasižiūrėti ar per niekur netraukia oro. |
PHObas55
Pranešimai: 30
Parašyta 2014-07-08 20:03 |
tai kad dar nemaciau kur vyks 4dieni tas meet'as, o kiap ta leak testa atlikt? gal kas esat susidure su panasia beda. nzn kur kreiptis, be audi centro, o ten kolkas nesinoretu varyt  |
kvatro
Pranešimai: 165
Įstojęs: 04.12.12 Miestas: Vilnius
Parašyta 2014-07-08 20:24 |
siulau i svalke varyt  |
PHObas55
Pranešimai: 30
Parašyta 2014-07-08 22:25 |
aham buvo kilus mintis, nes nieks nzn del ko gali but misfir'iai ir ar kitos klaidos susijusios, nes jos anksciau atsirado uz tuos trukciojimus... |
Elektrik
Pranešimai: 1334
Parašyta 2014-07-08 23:16 |
Leakas - su kompresoriumi įpūsti į turbos šlangą, ir žiūrėt ar kur nešnypščia. O dėl audi centro - tai bereikalo, sumokėsi ta patį, bet gausi kvalifikuotą apžiūrą su tikslingais įrankiai, ir gali būti, kad bėdą išspręs labai paprastai (pvz softą tereiktų atnaujinti) ar pan... |
PHObas55
Pranešimai: 30
Parašyta 2014-07-08 23:26 |
1
na as uzsirases pas juos, bet kai papasakojau kas yra su masina, kokios klaidos ir t.t., tai nepasirode, kad bus greitas sprendimo budas na bet lb tikiuosi, nes sake, kad pas geriausia elktrika uzrase... |
Elektrik
Pranešimai: 1334
Parašyta 2014-07-08 23:53 |
Na duodu 80% kad bus leakas šlangose arba amen PCV vožtuvui kažkuriam (karterio ir galvos dangtelio vėdinimo sistemos) kuris varo papildomą orą į įsiurbimo koliką ir per liesai dirba, kai per daug oro tada misfirinina, dūsliai dirba, purtosi, nes negali sureguliuoti apsūkų ir t.t. Tai čia audicentras turėtų akimirksniu surasti (su spec purškalais / oro pripūtimu ir pan. |
PHObas55
Pranešimai: 30
Parašyta 2014-07-09 00:03 |
na paziuresim ar lb greit suras ar nea aisku noretusi iki ju surast beda
Elektrik
Pranešimai: 1334
Parašyta 2014-07-30 13:38 |
Tai kaip ten sekėsi, surado ?  |
